check all your connections to the afm
check to see if nothing is unpluged mate
kool will do that cheers
also forgot to mention that when driving the hicas light will randomly flick on then straight off n the steering goes funny for that split second.
Another thing too is that when driving under light throtle (under 3000rpm) my car starts to like jerk.
This all happened after that guy started to take my headlight out but didnt n then put it all back together while he worked on it out side while it was lightly raining...and its fkn anoyying the shit out of me :P
also got hungry's half price when i woked at city cross (had nothing to do with the ''realations'' i had with the manager) :yes:
hehe, yeah, i forget the store managers name now.... the big lady....
apparently this certain ''friend'' of mine had a baby....
Stop humping the boss! :D
I am up for that
i need my plugs changed but dont know how to regap those f**kers
what the???? changing and gapping plugs is like the easiest thing to do on a motor, cant beleive everyone on here whinges like its so hard :yes:
whats the point in owning a modded car, or any car at all for that fact, and want to be called an enthusiast when you have no idea or no will to get your hands dirty and learn...
Fark me, workshops must make a killing out of some of you guys
end rant
you can't exepct everyone to know everything about their cars, thats why there are workshops around, professionals who do it every day. I bought my car knowing f**k all about skylines, but i know a hell of alot more know, and just because i need or ask for help for some stuff doesnt mean im not an enthusiast.
end rant
I know how to change spark plugs and have done it on the 33 but have idea how to gap - I've only heard of people talking about it but havent done it myself because it hasnt been necessary for me yet - we all got to start somewhere to gain the knowledge!
Instead of ranting I'm sure you can explain how to gap them yeah? :D When the time comes I'd just SAU-search for google it anyways.
I agree. Gapping plugs is the easiest job on earth.
However some people are not comfortable with doing it themselves until they've seen it done. Then they'll be kicking themselves because its so easy.
You simply need feeler gauges. Head to Vilis tonite with tool kit. I'll bring my feeler gauges and show you how to do it. :yes:
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
