Bloody hell I just woke up in the most painful way ever... for some reason I seem to have woke up as my body leaned forward then BACK DOWN WITH MY HEAD INTO THE f**kING CORNER OF THE BEDSIDE TABLE.... f**k.... yeah laid back down clutching my head in pain... smelled blood f**k turn on light theres blood on my hand. Great. Wash it off, grab some tissues, some ice and a couple panadols....... far out I can feel a descent bruise there already...
Well atleast it got me up to turn the computer off as the downloads has finish. Got a few hours of sleep til I need to be up... and I'll just sit here a little bit longer until the pain subsides.
Vu you fail at waking up :)
Clean? Are you serious!? It was last washed properly for the Stag cruise, lol. Ryan works night shift and there's no undercover parking so it was out in all that rain we had the Monday night.. I guess that was enough to clean it off a bit. I have noticed it needs a detail because you can see swirl patterns all over it when the car's in the sun.
Sez
ps: thanks for complement Damo :)
Edited by Ryan&Sez
Sez
must be coz its black, you see a flash of it and it looks clean :)
Should try that at the next picnic event! :D:)
18x8.5 +30 and 18x9.5 +30. Rears sit perfect, fronts could use a spacer to fill the guards better.
sizes on that S15 i think were 9.5F and 10 or 10.5R
Edited by muirsky
http://speedhunters.com/archive/2008/07/02...inimal-s15.aspx
The exterior enhancement consist of Spec-R side skirts and rear spats, that's basically it. Of course the other most noticeable change on the outside are the massive Work Meister 3 piece wheels in 18x9 in front and 18x10 in the rear, et is +4 all around.
How's that for a wheel fitment Antonio?
The suspension setup has been set to 5 degrees of negative camber all around. To do this Terry used Cusco and Tein Control Arms, Fortune Camber Plates and Fortune 40 way adjustable coilovers with 50mm pistons. The standard brakes have been upgraded with Project Mu brake pads and stainless lines.
Lol, 5 degrees of camber.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
