Bloody hell I just woke up in the most painful way ever... for some reason I seem to have woke up as my body leaned forward then BACK DOWN WITH MY HEAD INTO THE f**kING CORNER OF THE BEDSIDE TABLE.... f**k.... yeah laid back down clutching my head in pain... smelled blood f**k turn on light theres blood on my hand. Great. Wash it off, grab some tissues, some ice and a couple panadols....... far out I can feel a descent bruise there already...
Well atleast it got me up to turn the computer off as the downloads has finish. Got a few hours of sleep til I need to be up... and I'll just sit here a little bit longer until the pain subsides.
Vu you fail at waking up :)
Clean? Are you serious!? It was last washed properly for the Stag cruise, lol. Ryan works night shift and there's no undercover parking so it was out in all that rain we had the Monday night.. I guess that was enough to clean it off a bit. I have noticed it needs a detail because you can see swirl patterns all over it when the car's in the sun.
Sez
ps: thanks for complement Damo :)
Edited by Ryan&Sez
Sez
must be coz its black, you see a flash of it and it looks clean :)
Should try that at the next picnic event! :D:)
18x8.5 +30 and 18x9.5 +30. Rears sit perfect, fronts could use a spacer to fill the guards better.
sizes on that S15 i think were 9.5F and 10 or 10.5R
Edited by muirsky
http://speedhunters.com/archive/2008/07/02...inimal-s15.aspx
The exterior enhancement consist of Spec-R side skirts and rear spats, that's basically it. Of course the other most noticeable change on the outside are the massive Work Meister 3 piece wheels in 18x9 in front and 18x10 in the rear, et is +4 all around.
How's that for a wheel fitment Antonio?
The suspension setup has been set to 5 degrees of negative camber all around. To do this Terry used Cusco and Tein Control Arms, Fortune Camber Plates and Fortune 40 way adjustable coilovers with 50mm pistons. The standard brakes have been upgraded with Project Mu brake pads and stainless lines.
Lol, 5 degrees of camber.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
