yeh bru i sedd chep izz.
na in all seriousness he doesnt get a good enough wrap, he did a great job on my 33
and even explained in detail what he did, (put it back on the hoist to show me)
your receipt even comes with a smiley face sticker on it :)
no probs
now, next time i see you at the cass, and you see me swap your cards for my cards.dont dob.
haha, i wont, i dont care. the eye in the sky constantly monitoring my tables might though.
haha, he's already dropped it from $138K to $125 (13 grand...BANG)...........me thinks he'll drop another $50K off that figure before anyone even blinks at it!!
new rear tyres today! 235/45/17 IPROs apparently tested and perform to standard of the much bigger name tyres. They are only going on the rear anyway. Anyone else need some?
why not say there MA-IPRO Victra MAXXIS tyres how much did you pay for them i used to be able to get these at a reasonable price but prolly not as cheap as Steve
my HERO's are 1mm off the wear indicator what sux is there is still like 3mm of groove left after that or at least 2mm
im guessing this is the tread patttern
:) bloody security guards always wrecking my fun
:) jks
i used to be one, couldnt handle the shit at my young age.. im not scared to admit it..
its definately a real mans job.
you wanna try doing it for 10 years Craig..........I'm so over that scene!!
no thanks lol
i did 1 year in clubs.like Alma, rocket bar, Arkaba etc and i hated it, was good money though.
then i did a year mall security at city cross, shit work, but had good rewards :nyaanyaa:
still hated it though..
too many hero's out there! and honestly a 19 yo kid (me at the time)
has no chance against a raging drunk 25+yo...
there really does need to be stricter rules as to who can work as a bouncer.
my 0.02 Y
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
