Straight to the point, looked (by accident) the keys in the boot of the GTR... Boot release doesnt work, so.. How to get them out, havta catch the damn bus to work cos my daily drive keys are on there also :banana:... Raa be able to 'break in' to it?
Also was lucky the boot didnt catch on fire as the rear right hand light has burnt out the left globe and wiring, hence the reason i was in the boot, put my keys down for a second and with the frustration of the rear light almost catching alight i shut the boot with them in it... What to do? Any ideas.. Stupid problem i know.
cronic a little information you may have missed
hey wat causes missfire?
coilpacks, plugs...
i have changed plugs and gapped them, and used another set of OEM coilpacks and still missfiring.
any ideas on wat else i can change? coilpack loom??
coilpacks, plugs...
Timing could be way out? Did you plug everything in properly?
yeh timing was done when the water pump was changed 3km's ago lol...
im thinking the OEM coilpacks are not coping again...
s1 or s2
if its a s1 rb25det check the ignitor could be playing funny buggers just a suggestion.
Well the RAA dude this morning got the keys out, dont know how as i wasnt there, apparently they have a 'special way' of opening a boot lol
Anyways all good, thanks for the help people.
Now to buy a new boot lock, anyone know where i can buy one from? Thinking nisswreck or similar..
Whootage
Cleaned my car just before, the piece of shit actually tubs up alright (if you don't look at the back) :)
Also swapped the innards of the dizzy over on the poobucket daily and it drove roughly a million times better. Still got a very occaisional misfire, but it's been run down to 5/8ths of fk all petty a few times and the fuel filter has probably picked up some crap, so I've got a new one to put in when I cbf.
All in all a good days work ;)
Edited by AndrewJZX100
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
