Straight to the point, looked (by accident) the keys in the boot of the GTR... Boot release doesnt work, so.. How to get them out, havta catch the damn bus to work cos my daily drive keys are on there also :banana:... Raa be able to 'break in' to it?
Also was lucky the boot didnt catch on fire as the rear right hand light has burnt out the left globe and wiring, hence the reason i was in the boot, put my keys down for a second and with the frustration of the rear light almost catching alight i shut the boot with them in it... What to do? Any ideas.. Stupid problem i know.
cronic a little information you may have missed
hey wat causes missfire?
coilpacks, plugs...
i have changed plugs and gapped them, and used another set of OEM coilpacks and still missfiring.
any ideas on wat else i can change? coilpack loom??
coilpacks, plugs...
Timing could be way out? Did you plug everything in properly?
yeh timing was done when the water pump was changed 3km's ago lol...
im thinking the OEM coilpacks are not coping again...
s1 or s2
if its a s1 rb25det check the ignitor could be playing funny buggers just a suggestion.
Well the RAA dude this morning got the keys out, dont know how as i wasnt there, apparently they have a 'special way' of opening a boot lol
Anyways all good, thanks for the help people.
Now to buy a new boot lock, anyone know where i can buy one from? Thinking nisswreck or similar..
Whootage
Cleaned my car just before, the piece of shit actually tubs up alright (if you don't look at the back) :)
Also swapped the innards of the dizzy over on the poobucket daily and it drove roughly a million times better. Still got a very occaisional misfire, but it's been run down to 5/8ths of fk all petty a few times and the fuel filter has probably picked up some crap, so I've got a new one to put in when I cbf.
All in all a good days work ;)
Edited by AndrewJZX100
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
