is there a toyota chaser forum???
http://jzx100.com/
hey chad, with the hid's, add this bloke to msn; [email protected], hes known as 'angry' on the r31 forums, has sold about 90 hid kits there, good bloke to deal with, knows his shit pretty well.
jzx100.com
also, this place clearly needs a mod who drives an s14.
and i was beaten to it :(
bingo
ive got them, orgzmc has them in his drifter, and madaz bought a set earlier in the year good bloke to deal with definitely
yes great kit, and i got auto perfection to install mine
EDIT
after a little looking it seems another fine forum (im guessing its fine) comes from SA
the registrant of JZX100.com is
Registrant:
Random Seed Design
50 Tarqui Dr
Paralowie, South Australia 5108
Australia
You're gain, Luke! There's a huuuge RBT/defect blitz on tonight!!
Yeah we saw one rbt just out of the city. Thought it would be the last drive before i go to qld on friday.
And Dave was a last minute thing, was just a quick eagles, greenhill, lofty run.
Wow... I just realised Cubes has 'retired' from SAU's moderator team and now Heslo's a mod here...
cubes bought a whole 3rd dimension to the sa sau section now where stuck with this 1 dimensional sled character jeez
a picture to demonstrate :( these dimensions for the ill informed
post-31501-1230692129_thumb.png[
and finished cubes
i take it he didnt have much time for it as he was hardly posting on here as of late.
a new reign of terror shall now commence
this post almost became educational
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
