how much? will they fit in the single DIN position under my stereo???
are they out of a r33?
They'd fit in a din sized slot easily, the main thing you have to find out is if the cables are there for them to plug in - integrated GTR gauges get their readings from the ECU, not an independant sensor. My GTR's centre gauges have two plastic plugs that clip in to the back, not sure if those plugs are there on 33's and 34's or non GTR's
-D
need $100ono to go towards new tyres on the front of my car as they are forked.
yes its single din , i had em in my skyline just to fill the gap between my air con and fold out screen
yes they are from an R33
as Dohmar said above^^^^
do u have the plugs for them???
i'm not gonr hook them up 2 my ecu, i just need the plug to have the pos/neg/illumination wires, thats all ill hook up
by the looks of it, in a GTR it must of been where the climate control was coz the right side has no corner so if i fit it under my stereo there will be a slight gap
nah dont have any plugs , just the unit its self
here is my stealth ute shes a monster now with the black sunnies and truck pipes, wonder how long till the cops pull me over bout it. :)
keep a look out for this at glandambo 4x4 event if anyone here goes to it you might see me there this year. im gunna jump the table top and land in the mudpit, hopefully land on all fours.
on another note is it illegal to have your cam gear cover off as i want to get some purdy red cam gears.
have u got a tray on the back of that? can guarantee with no tray or protection over the rear wheels you'll get looked at, but otherwise id say it'll be stealthy :)
    • And what is the significance of the Italian word for "reserved"? AFAIK, it means nothing WRT GTRs.
    • There's no way that we can tell what they were for because they are not stock. Somebody had something installed that needed an earth and took it 98% out.
    • Hey SAU,  I pulled my fascia apart to remove my cluster and found these snipped grounded wires, and a black wire off to the side. I was wondering if anyone knew what these were for?  To note: My headunit is not powered and has not been since I purchased the vehicle the cigarette lighter was not hooked up either, unsure if this has anything to do with it?
    • Welcome!  Any pics of the new GTR? You'd be amazed how many people have minimal plans initially. 🤣
    • Hello all I've been lurking around and reading many threads for quite some time, so I figured I may as well join in. I recently picked up a R33 GTR 3 V-SPEC RISERVATA that’s mostly stock. The car has always been a bit of a dream for me, and now I’m slowly starting to plan the next steps — nothing too crazy yet, but I’d like to keep it clean and responsive while pushing a bit more power.
