That's a pretty good result, Mitch.
Considering stock standard RB26's will pull between 170kw and 180kw at the rears with the 4WD fuse taken out (R32's) on stock boost (meaning the restrictor still in).
Mine pulled 174.6kw at the rears on stock boost (the GTR still has the stock boost restriction in it! Never been touched), stock turbos, 3 leaking injectors (found that when it was on the dyno), a collapsed centre muffler baffle and a stuffed cat. No ecu mods, no EBC, stock intercooler... only mods are twin Blitz pods. Pretty good result! And the engine is in good condition (170psi across all 6 on a compression test, leak down test proved it's healthy, too).
Once I've replaced the exhaust with a full new system, I'll put it back on the dyno and see what I get. The injectors have already been fixed. My exhaust is that badly clogged, that I can expect to see a large difference (like, 20kw or 30kw extra lol).
Mitch, What do you mean you've modified the coilpacks? If you've ripped out the stock coils and put in Splitfires thinking it'll improve performance... you've wasted your money. Nissan Standard Coilpacks are the best you can buy... Splitfires are a cheaper alternative.
Edited by CRoNic...
yeah it doesnt really explain itself all that much. you have to determine if the argument is logical. a hint.
All ducks quack
donald is a duck
therefore donald quacks. It states that ALL ducks quack, and Donald is a duck, so it as a valid argument.
I agree steve my mates GT went from 224 at Aussies to 257 at KPM with the addition of underdrive pulleys only :D (which in reality would be 5-10rwkw at the most). Hows your car doing mate got it sorted?
had my car dyno'd at MRE, then 2 months later no more mods done got a reading at KPM that was 20rwkw higher :s
yeah im not saying its a performance mod, its the only thing thats been changed on the motor its self :P
Dyno readout's differ due to different shoot out modes used the amount of brake that is used to simulate road conditions
damo will post my thoughts later when im home about that logics test
Nozila - where did you get defected
mitch, a cop pulled you over and issues that?
yep , pathetic if you ask me but hey, he was nice and liked my car and wasnt out to defect me , just sucks being unemployed at present and having to pay this fine and get new tyres , but oh well
least i can still drive
Yeah i was thinking of taking mine there to see if i could squeeze 300 out of her :P
What exactly was the fine for?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
