That's a pretty good result, Mitch.
Considering stock standard RB26's will pull between 170kw and 180kw at the rears with the 4WD fuse taken out (R32's) on stock boost (meaning the restrictor still in).
Mine pulled 174.6kw at the rears on stock boost (the GTR still has the stock boost restriction in it! Never been touched), stock turbos, 3 leaking injectors (found that when it was on the dyno), a collapsed centre muffler baffle and a stuffed cat. No ecu mods, no EBC, stock intercooler... only mods are twin Blitz pods. Pretty good result! And the engine is in good condition (170psi across all 6 on a compression test, leak down test proved it's healthy, too).
Once I've replaced the exhaust with a full new system, I'll put it back on the dyno and see what I get. The injectors have already been fixed. My exhaust is that badly clogged, that I can expect to see a large difference (like, 20kw or 30kw extra lol).
Mitch, What do you mean you've modified the coilpacks? If you've ripped out the stock coils and put in Splitfires thinking it'll improve performance... you've wasted your money. Nissan Standard Coilpacks are the best you can buy... Splitfires are a cheaper alternative.
Edited by CRoNic...
yeah it doesnt really explain itself all that much. you have to determine if the argument is logical. a hint.
All ducks quack
donald is a duck
therefore donald quacks. It states that ALL ducks quack, and Donald is a duck, so it as a valid argument.
I agree steve my mates GT went from 224 at Aussies to 257 at KPM with the addition of underdrive pulleys only :D (which in reality would be 5-10rwkw at the most). Hows your car doing mate got it sorted?
had my car dyno'd at MRE, then 2 months later no more mods done got a reading at KPM that was 20rwkw higher :s
yeah im not saying its a performance mod, its the only thing thats been changed on the motor its self :P
Dyno readout's differ due to different shoot out modes used the amount of brake that is used to simulate road conditions
damo will post my thoughts later when im home about that logics test
Nozila - where did you get defected
mitch, a cop pulled you over and issues that?
yep , pathetic if you ask me but hey, he was nice and liked my car and wasnt out to defect me , just sucks being unemployed at present and having to pay this fine and get new tyres , but oh well
least i can still drive
Yeah i was thinking of taking mine there to see if i could squeeze 300 out of her :P
What exactly was the fine for?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
