mm turning 21 was good, my insurance premium has dropped by $600 for my next year :) but my agreed value has dropped $2k :)
it wouldn't be cause you turned 21 that your insurance dropped its because the agreed value has dropped
.7
you generally wouldnt need to go any lower
Damo - that logic test, 1 of the questions i didnt like was #5
Answer 5.
a) Where there is poverty there is crime.
b) There is crime in Camberwell.
- Therefore there must be poverty in Camberwell.
Invalid. There may be crime where there is poverty, but it does not necessarily follow that wherever crime is there is poverty. There is plenty of crime occurring in wealthier circles.
where there is poverty there is crime is a truth statement its not guessing
there is crime in camberwell is again a truth statement
so how can it be invalid where not discussing how wealthy camberwell is just stating there is crime there
sweet..can they go lower due splitfires?
Ideally want a higher gap not a lower. I higher gap gives a better ignition to the fuel but it also is weaker spark which makes it susceptible to being "blown out" by the intake charge.
Anyhow the accepted gap is 0.8mm if you have split fires then you should be able to run a bigger gap but it'll be trial and error to find out how big and I wouldn't go over 1>1.1mm anyway.
Edited by D_Stirls
hmmm.... ok i think there at .8 atm... thats wat they are from the box?
i can just feel the car hold back constantly then be ok the hold back due to missing...
ill open them up more... trial and error i guess..
what is the last number on the part number? If it had some thing like BKPR6ES-8 then it is 0.8 but if it was -11 or didn't have a number at the end then it's 1.1mm
If you are having spark problem then opening them up won't help you need to close them up, but if you have split fires then you shouldn't be having spark problems. you will know if they are breaking down because it'll sound like it not running on all cylinders where as you are saying it's feeling like it's being held back which isn't spark. It's probably got more to do with ignition timing.
Edited by D_Stirls
Surely dropping my agreed value from 23,900 to 21,850 wont bring my insurance premium from 2098 p/a to 1500 p/a. if thats the case, ill set agreed value at 18k and pay no insurance.
Rhys, yep just car, got the info from my policy renewal letter, expires early Feb.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
