any1 giving away a 2 seater lounge??? wanna put 1 in my room, just bought the new HP touch screen computer n everything is wireless (mouse, keyboard) so i dont have to sit at a bloody desk all the time
from memory there we some seats in the for sale thread (dw just checked they were yours :ermm::P
hello everyone
Ok just got back from Dyno. Boost controller having trouble holding boost as it spikes to 25psi and by the end its at 19.5psi.
1st Run wheel spun its titties off so Pete had to tighten the straps more (made 279)
2nd run right up the top off the torque range it lost traction again and the graph fell away (made 323.8)
3rd run the heat had set in but still managed 323.2 and still wheel spun a touch up the top of the torque.
If i can get the boost to hold more stable who knows possible. I will post the dyno graph in the RB25 upgrade thread sometime today.
I owe all this to AD (aka180or200)who has done an absolutely brilliant job on tuning my car. Your a legend mate.
Needless to say i'm stoked with the outcome.
yea and we got one person to thank for it.
Niel is only doing his job....if you have a defectable car then you run the risk of being picked up....it's simple....we have regulations there for a reason and if your car isn't within those regs then pay the price to get it fixed.
Thats one reason why I've removed the mod stuff from my Stagea. Even the exhaust which has a big muffler and tip is very quiet for its size. I took it to the exhaust shop 3 times until I was happy with its noise level. Still got the cat in it too, and fitted a larger resonator, even has a new O2 sensor to ensure its running clean. My car looks great with the body kit and thats about all I need right now. I have my bikes and track days if I wanna go fast.
Getting the silver S1 Stagea registered soon now I've replaced the waterpump, O2 sensor and timing belt. Engine and gearbox has been serviced. I'll be driving that around next month when the black S2 Stagea's rego runs out. The silver stagea is as stock as they come. I can't sell it, so I might as well drive it.
Edited by RubyRS4
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
