really?
... how much?
ok i'll post it up since you all want to know it cost $550 Its an Earls cooler measuring 12x6x2'' 19 row, Perma-cool adapters, Speedfow fittings and Speedflow hose. All good quality parts.
Looks good Chad - where you gonna put the oil filter??
I'll probably set it up similar to yours. I just dont want it to hang down to low, dont want it to be able to be hit if i run over a stick or something. Was gonna ask if you were maybe able to help me?? as i dont have spanners big enough to do up all the fittings.
sure - but I'm probably going away for 3 weeks on Tuesday. One week early. Thats one week less to get ready for the track day. Any of the next couple of days is fine :-) just might have to get out and about to grab swaybars and springs for a bit inbetween.
not easy being a big fella in a small fellas car.
and nissan oil filter placement is retarded. seriously. who the f**k puts a filter there?
haha that is nothing my friend....some of the machines at work are close to being impossible to get to and there are about 12 of them on one machine and 10 times bigger.
and for all the other chilli fans out there:
http://www.deathsauce.com.au/3amreserve.html
here is an excerpt of the heat rating of this :
Heat Index:
3 a.m. Reserve is not a sauce, it's an ingredient and is too hot to rate. If you're interested in buying this product, read the instructions below to fill out the disclaimer form mail it to address below or scan signed disclaimer and e-mail to us. You cannot receive this product without signing and returning the disclaimer.
he is not joking either.. i have had a couple bottles of mega death sauce in my time, and they are fk off hot (no im not a chilli wuss either :happy:)
I might leave you in peace to get your own stuff sorted then. I have to go back to work on Monday as well. I should have the tools at work i can use. if not, there are a few mechanics near my work if i get stuck.
IM GIVING AWAY SOME R33 SERIES 1 DOOR TRIMS (GOOD CONDITION) LEFT, RIGHT, FRONT, BACK FOR FREEEEEEEEEEE
IF THEY ARE NOT WANTED THEN IM GOING TO THROW THEM IN THE MINI SKIP ON THE WEEKEND, NEED GONE ASAP
PICK UP ONLY
DAN 0402541975
Okay, now that's kinda freakin' me out .. :) ... this is maybe 2 hours since I brought up doing a groupbuy at my work for baconsalt ...
(... I'm guessing this is due to Adelaide being a tiny place ... )
lol. yeah i heard about it around then LOL gotta love corporate email... im glad that news of important things sweeps adelaide quickly
    • Good tips, will get on those tomorrow. When doing the maintenance I did move a few of those connectors around, and things that are old tend to not like moving around. (Like me).
    • Don't try it. It will be shit. Better chance of damaging the engine than gaining any knowledge about the old one. Maybe, but unlikely, especially if the O2 sensor is working. You can use NissDataScan to look at the stock ECU.   Cleaning the AFM is seldom necessary and seldom helps. The R35 coil & loom conversion should eliminate dud coils or plugs. But as you still have misses - look to the plug where the coil loom connects to the engine loom, and the CAS plug. Need quality connections there. Also look to injector plugs. And the AFM plug while you're at it. Also look to whether your injectors are clean and flowing evenly. Get them out and onto a testbench.
    • Good to know, I feel like I am in for a rollercoaster ride that looks like a sine wave.
    • You'll fit right in. Acceptance is the first step.
    • Hey folks. I've been lurking and browsing the forum for a while, since I got into my head that I wanted a skyline. Having purchased an overpriced completely stock GTT, (only "mods" it has is HKS pod filter and catback) now that it became legal in the US, it was all glorious and sututu noises here and there. But then I wanted to do things right and went to do basic maintenance. After all the fluids, filters done, I did the spark plugs, that's when the problems started.. First the car started spluttering at around 4.5k RPM. Which I gapped down the new plugs and that solved the sputter there, but the car now always misfires at idle with pops when lifting off and shifting 2nd to 3rd. Similar to the issues in this recent thread. I've been banging my head against the wall, reading the threads here and trying suggestions for a couple months now, so decided to start this one to explain exactly what I tried and what is going on. The symptoms of the issue: Idle and low revs misfiring intermittently. You can hear the exhaust tone change and the shakes on the shifter knob. It happens frequently, but doesn't seem to have a rhythm to it. Pops when backing off throttle. It pops and or burbles almost feels like it spits fire when it pops. (Happens mostly in 3rd gear at around 2k RPM). When under load and after 6k RPM, it also pops when shifting from 2nd to 3rd. There's a ticking noise at around 2k RPM in 2nd gear going downhill, seems unrelated though but I am out of educated and downright dumb guesses. Not noticeable lack of power when putting the car into load. The attempted diagnosis and solutions: Unplugging coils when the car is running This did nothing to change the idling and tone shift for every cylinder. Checking the exhaust headers with thermometer They all are within what I'd say it is margin of error of the laser thermometer New spark plugs Tossed two new sets, copper, iridium and using the old ones, still misfiring, even re gapped to 0.8mm, still same thing. MAF cleaned with the "specific" spray cleaner No changes in the issues what so ever. Brand new loom and r35 coil conversion (was going to add the r35 coils anyway) car runs arguably better, still misfires, but seems like does less frequently. Placebo? Code 21 now being thrown, thanks nissan gods. Removed the CAS to check the shaft for play or anything. CAS seems all fine, nothing that indicates any issue, visually speaking. Things to attempted next: Ordered a new MAF (chinesium from Amazon, to be able to return regardless of result). Fuel with proper gas, maybe it is this California water that they sell as gas that is to blame? Plugin the link ECU and check the info using the built in base map. Go back to BMW and eat my rob bearing breakfast without milky oil mixture.   Do any of you have experienced anything like this or have any suggestion?
