Anyone (Ryan?) got an air ratchet? Similar to what the tyre shops use on wheel nuts?
I've got a huge 36mm nut to remove off a bike's clutch basket, but even the breaker bar won't budge it. ;) Thinking an air racket tool would be the trick.
Anyone?
:P
my uncle got his unrego'd falcoooon defected in his garage while in the middle of putting a 351 clevo in it ;)
(thats his fault for hiding stolen goods in his shed but)
but yes, no where is defect free.
I'm tied up all weekend with parties and functions.
But I still got a days ride in today thru the hills ;)
Refitted my Corse race pipes to the MV and she sounds sweeeeet!!!
Riding to my brother's place in about 20 minutes ... its his birthday :P
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
