man did the GTR hate being driven in 45 degree weather, all kinds of random noises start apearing lol
Agreed. On the way home yesterday I had some major idle / power loss issues. Spent an hour changing the air flow meters. 1st one I replaced, went for a test drive - same problem happened.
Replaced the second one, problem hasn't shown itself again (yet - touch wood) but I'm eager to see if this afternoon changes the story.
Oh and +1 for joeleo for reconditioning the afm I lent him - I've chucked it back in and its not screwing up like before haha - thanks
-D
not bad at all Damo and if it's a real good one and you could screw him down to $25K......i'd say good deal.
my preference would be all original dead stock V-Spec II and leave it that way.
the 200's back! yay! new clutch is nice, friction points a lot higher on the pedal than the last one, so its gonna take a bit of getting used to. shifts are so tight though, its awesome.
... but i apparently need to replace my turbo studs sometime soon. f**k.
that cars made an appearance on the 'stupidest things youve seen done to a car' thread on the 31 club...
... about 5 times.
Edited by scandyflick
-D
sure its not your inlet temp sensor taking timing out the car cause its hot
Weeeell no not sure at all.... where is the inlet temp sensor? The problem is sporadic (aka in the 20 minute drive, it probably lost power/started to stall 3-4 times but a little bit more accelerator helped it out of the stuttering...)
If I can clean it or check the wires, it'd be a good place to start...
-D
Its right at the front of the Plenum, but i doubt that is the problem.
Inside the plenum or outside? Would love a pic if anyone has one? :blink: I'll see what happens on the way home - if I get some twitching ill pull over and give it a bit of a wiggle, maybe test it with a multimeter when I get home
-D
-D
Here it is i think.
Got my new type M front bar today. I'd love to get around to fitting it tonight, but its too freakin hot.
I'll leave it until the weekend. Might still take a pic tho :blink:
fuuk you ETSA
last night we where without power from 7 pm till 4:30 am, which = me getting no sleep.
we had to sit outside cos it was so hot inside.
get this, my aquarium heater is set at 27 deg. the thermometer always shows round 26 ish
when the power went off yesterday, i feared that maybe the water would cool and the fish would die,
nope, the exact opposite, it got so hot in here, the water temp went UP to 31 deg at 2:30 this morning.
by the time the place got cool again and i fell asleep it was 5:30 am
and guess what i come home to this afternoon? yup, power cut.
thanks ETSA.
That was so foul, no one bought it for even $4K ;)
What is it with these fools who do up Magnas? :blink: I saw one the other day lowered to all hell, with dark, dark tint and loud exhaust. Don't these fools know they're not a car you bling!?!
I owed 3 Magnas and I never did any of that shit ... waste of money!
Lol try saying that on the Magna Car Club of SA haha!! They're nuts on that forum. They love the Magna's!!
Lol I wouldn't even dare to start up my GTR in this heat. It'd suck enough hot air in just idling!
Same, and i deff would't even think about hitting boost, imagine the air temps going into the motor. I dont think the intercooler would do much in this heat. Probably just heat the air more :blink:
It's a bit sus, Kye. What if the guy on the bike ran into the car? What if he had no reflective gear? Etc.
its also the fact that since there is NO sholder on the road heading towards victor/mclaren vale, means the bike rider was riding on the road in the actual lane plus there are no street lights at all so its pitch black.
so if the guy didnt do a runner, he may have been let off abit lighter.
Haha - you know about Terry Kennedy and his diss track to Lupe? "Kick Push Pass".... its all documented in one of the Beef series (number 4 I think) but I think its funny as hell - they interview a bunch of skaters and say 'all lupe did was a little ollie at the end of his video'
-D
haha nah i havent heard that one. everytime i see him on tv i laugh though haha.
wouldnt suprise me if thats all he did in a skate vid. that was pretty much all he could do :(
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
