have a look in the radiator, if there the level in there is fine (down around 1-2cm) then just top it up with distilled water and the same with the over flow tank.
Yeah pretty sure the radiator is fairly full as I only checked the coolant a month or so ago and the overflow bottle still had something in it, just over the last few weeks it must have used the rest up.
So don't even top up the overflow with coolant, just use water?
I gave them a call there open till 4.00
I got a note on my font door saying that they try'd to deliver something to me today, i think it might of been my new Brake pads :D so i have to go pick it up after 2. i didn't know they delivered on Saturday's.
You can top it up with coolant if your 100% sure that you have the same brand and make of coolant that is already in the engine. If you mix active ingredients there is a chance that they can react and will turn to jelly, which isn't a good thing the have in your water jackets. Water is a safe option if your not sure since you are going to be changing it soon.
Thanks mate.
EDIT- If it just so happens to turn to jelly, what would I do about it? Just flush the radiator?
Edited by muirsky
i missed pendulum to see lupe, was still amazing but yeh prodigy was insane, like 15,000 people all going nuts when the bassline hit for smack my bitch up
+1 eye candy.
pendulum were good.
but I thought prodigy were kinda average to be honest.
They talked way too much shit instead of letting their good tunes do the work.
Some of the nice sounds and basslines were spoilt because of the stupid screaming etc they were doing.
good day out tho... :P
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
