yeah i got a warning for it LOLLLL O WAT EVERRRRRRRR this is a joke i was refering to mitch im sure he doesnt take it PERSONALLY do you? ahahahahahhaha but i guess i hurt someone else feelings ahahhah SNAP
you know kietz you are such a hero where you stand my friend........but that's only because I've never had the pleasure of meeting you.....trust me when I say that you would be a little more respectful otherwise
there were 3 guys in my targets tonight and only one of them turned out to be a real man via PM (Tom).......the other 2 continued to act like little school girls
However, this is Wasteland so feel free to continue to act like dicks but you'll feel pretty silly next time we're all out on an SAU event and we cross paths........might be somewhat embarrassing me thinks
and you just pm'd me 'Treat all members with respect and courtesy - We will ban any member(s) who make personal attacks, threats or mistreats any other member in anyway (discretion is up to the moderator at the time of the offence)' tskkk im going bed now for real now. had enough of this bs
SEEING AS GOOGLE WONT LET ME GET THE GROUP HUGZ PICTURE
i am posting in words
Pete , sorry if you mistook my humour to be personal . it wasnt intended to be .
now you can take this as a genuine sorry or you can take it at face value and not care about it .
your choice.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
