I do
morphett vale, pm me
Cheers for the offer, i'm at campbelltown so by the time i drive down there to pick them up and then drop them off i might as well as bought a set as their only around $40. Thanks again though
Anyone in the north have any spring compressors?
like these ?
ive got a pair but they are at a mates , ill get em back this week and you can borrow them if you'd like ?
Arse, shenanigans went on last night and I missed it :(
anyone going to the ben simpson cruise? i might drop by with a few work mates for an easy drive!
I'm going ;)
Hoping there'll be some other cars as slow as mine so I don't get lost :D
If last night was anything to go by it should be great weather for a drive tonight.
I'm going :D
Yeah me too...Went for a quick cruise last night, Henley etc was pumping.
cops were left right and centre at the cruise so i left! there was a white falcon parked next to me with SAU stickers, who would that be?
Yeah that is Luke (and Flick)'s car Son - that's where I disappeared to - had to go steal some fries off them at Hungry Jacks and have a chat.
Spewing I had to go out to dinner rather than cruise - but at least I came down to say Hi to some peeps at the meet-point :sick:
anyone else here got an rc drift car? got any good locations that you frequent with it? ive heard of an old rc drift track in regency area, anyone heard of it?
yeah , i used to race there with my cars
ill find a map of it after i finish dinner and post it up
Went out for a nice cruise last night about 1 till 5.30 ish this morning no cops around. Went down south it was a great night for it finally got to open the car that i just got up. Great night didn't see many cars out at all.
yeah you left at the right time! after you left cops were pulling alot of cars over outside the carpark and apparently traffic cops were comming or something. i thought since i wasn't gonna cruise i'll leg it as well
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
