I know its bad, but I laughed at some of the racist ones they got on there too
I laughed, well it was more of a sAfrican American "holy crap you cant say that can you"
for eg.
The Koran. now in 2 ply
or
arrest black babies before they become criminals
or
SLAVERY: gets shit done
Warning: Damo_R34 does not condone racism, above post contains the views of tshirthell.com and not that of SAU.
If that place is in melbourne he made a very bad attempt at making a blasphemy shirt and he was told by police to stop making them due to over 10,000 complaints
its all good and well that you dont believe but there is no need to poo poo someones faith
But its an >ENGLISH< game. Give me Aussie Rules Football for a slice of dinkum australiana
-D
CORRECT.....Andrew's a Tea Totaller though so we have to make exceptions :P
Yeah! I don't know how long its got to go!
Hey Sled, any of our new tshirthell.com avatars bad for the website?
as long as I don't receive a PM from someone who's taken offense.......keep in mind though boys, SAU is a family friendly site so I'll leave it up to your discretion
Thought I'd ask though. Don't want to receive any warnings for an offensive avatar, but aslong as people realise its just abit of fun.
:P
just wondering if someone with the right picture editing program can turn this into the appropriate size and pixel for avatar?? seems windows paint is a little obsolete. many thanks
try this mate
http://i114.photobucket.com/albums/n273/Da...-for-avatar.jpg
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
