hahaha you're welcome :happy:
But no-one is going to get the $950. No way this waste of money is getting through .... the Libs let it go once, but twice is just bad joojoo
*Sigh* I have nearly finished typing my valuations from today. I have my 1st job at 8:15am in the morning and my last one at 5:30pm tomorrow .... so home around 6:30pm, see the wife and child from some dinner, then around 6 hours of report typing tomorrow night :ninja: I had better go to bed. Soon.
Hahah I hope you're hungry mate, cos you have one hat to eat :ninja:
http://www.smh.com.au/news/national/stimul...3423344567.html
"Stimulus package passed after overnight debate"
-D
Heard on the radio this morning KRudd having a go at Malcolm Turnbull for halting the handout, claiming "he's hurting the economy but not allowing this money to reach our schools, hosptials ...". What a load of bullshit. It'd certainly reach the pokies, bottleshops and anything in between, maybe some school fees paid (but they need to be paid regardless), but def not our hospitals. Anyone who believes what KRudd says doesn't deserve the money anyway. :happy:
*God I tried so hard not to get in on this topic, but can't believe the rubbish coming out of KRudd's gob*
Edited by RubyRS4
MMM you're right. I'm going straight to the bottle-o and buying $950 worth of Wild the sphincter of the universe and Sparkling Ale
-D
You have no idea of my education level let alone my income.Believe it or not but your not the first person to go to uni. And poor you forgoing 4 years salary to do it, that sounds really tough, i'd be interested to know what 3 year uni course you did.
And why would i want a shitty job where i never get to see my family and all I do is complain about working on here.
Hmm and by your calcuations i earn't 120,000 dollars on that 12 grand tax i payed you know as i keep 90% of my income.
Once again lets ask around if you payed 45k tax you earnt around the 140 grand. I think most people would be happy to take that salary and pay the tax.
i believe that red, is in fact the best colour. discuss.
also, im fairly sure my internet is bouncing off the limiter. shit.
i think we should just admire Dave's new profile pic: THE BARRACUDA!!
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
