dedicated skidder unfortunately. would only come out for the larger cruises/driven the long way to a workshop...
seen it in the flesh, thing looks mean as, spesh with the full set of model 5's on :)
yeah, same, looks tough as. aussie kept the 5's when he traded it for the 100 im fairly sure. has some meshies on it at the mo which ill have my way with, probably rock a few sets of dori's as skidders.
Yeah, they looked gangstar on the 100 too :)
Dunno who's got them now, but it looked pretty good on those meshies anyway at the BSM cruise.
That 32 is taking a piss :)
My Stag does the same thing up my work driveway. Work mates have asked about it ... I just say the car is taking a piss! :)
Edited by RubyRS4
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
