so, turbo people, looking at getting a new turbo for the s14, as the stocker is one its way out. not thinking anything massive, got it down to a garrett GT28R or GT28RS, just wondering if anyone here has any experience with them? ill probably end up browsing the forced induction forum soon, just seeing if theres anyone here whos used either first.
cheers krish, completely forgot about dale. shall have to have a chat with him. 34 turbo sounds interesting, thinking lag could be an issue with the missing 500cc though. just looking for nice streetable power, somewhere around the 150-160rwkw mark.
Hey Dave,
If there is nothing wrong with your turbo then I would keep it fit a boost controller and go see Jeff (SpeedLab) for a remap. For around $500-$700 (my remap was around at or below the lower end of that scale but SR's need a daughter board installed which the CA's don't and the board costs around $250 by itself) your current turbo you will make around the 190rwkw mark. I have a feeling that you will be near the limit of your AFM at that point and you won't want to go to much further with your standard injectors, but you should get there.
If you want to go bigger turbo then you will be looking at at least 550cc injectors (but 740cc are the same price and they will give you more scope for improvements in the future improvements) remember that with 4 cylinders you have to go bigger with your injectors to make the same power as a 6 as there are less of them.
You will also need to a bigger AFM; once again you have choices a Z32 will support around the 320-350rwkw mark but costs anywhere from $200-$300 where as a SII RB25 AFM will support 230-240rwkw and will cost you around $50, and really even if you go for a GT2860RS you won't be making 230kw without cams.
If your still after up upgrade i would suggest the GT2860RS as a GT28R (A.K.A T28BB) is only ever so slighlty bigger than what you have on there from the factory
I would forget about the GT2871R as it's too big for what you are looking for as it will support 230-240kw without cams and 250-260kw with cams but come at the cost of response (full boost at around 3700-4000 depending on cam setup).
Anything else just ask
Edited by D_Stirls
sorry im agreeing with the doh man, sounded like a steam train trying to take off at first and also like it stalled about 6times. crommies also terrible.
if you gonna go v8 go for elenor or gt40 :)
you guy's do realise that it's supercharged as well and that is why the idle is up and down like that.
P.S. i think it sounds absolutely TOUGH, but then i did grow up around BIG V8s.
http://www.youtube.com/watch?v=wJNM3sHcwBY...re=channel_page
See the front mount at 0.24
Edited by D_Stirls
meh i dont care if its got 2000hp it sounds terrible to me,
but ive always been a exotic loving anti v8 type of person :)
although i have developed soft spots for the 2 above v8 mentioned cars and shelby cobra's
I have a soft spot for 1967-1969 chevy camaro's... 1st series... even today they look frigging awesome...
-D
Well you'd hate this thing then cos' it has a dirty old V8 in it ;)
lol now that sounds tuff, has tt attached much like f40s which are also tuff :)
i just dont really like the valliant style box cars pencil ruler design and engines that sound like they stalling or have metal getting chewed up inside.
but thats me feel free to disagree ya'll ;) i drive a rusty dato anyway
Edited by Inline 6
anyone want stickers made up for their cars that have reflective properties? ie the stuff road signs are made from?
like so: 006.jpg
ill take a barracuda. in red.
Hey Dave,
thanks for the advice mate. :)
fairly sure somethings not right with the current turbo, but ill wait til i pull it off the engine and have a good look at it. might just get it rebuilt and tuned.
cheers.
All this talking about ECU remapping has got me curious.
So, it's basically flashing the ECU? Everything on the outside/inside of the ECU is kept standard (eg. no chips soldered to it, etc) except the ROM data?
Would this mean, it's technically a way to get through Regency as opposed to having a Power FC or something else as your ECU?
Yes and no... you can reflash an ECU with another set of firmware which may or may not contain an updated map...
The map is EEPROM which stores a spreadsheet of air fuel ratios and other assorted timings, and is done by using a laptop in most cases, and can sometimes be done without any mods... r32 gtr ecu is reprogrammable but the 33 and 34's arent iirc. Thats one of the reasons people like to switch to aftermarket ecu's like PFC's because of the ability to change heaps of settings..
-D
and, lets face it, chicks dig live readouts on the pfc hand controller.
i dont haz pfc, oldschool gameboy with LAN cord going from gameboy to behind the dash will have to do till the funds allow :P
scandy, 3 spoke rims are made of fail............ IMHO
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
