Back from the World Superbikes at Phillip Island. Got back home at 3am this morning ... still feeling the big weekend. Working from 6.00am thru to 6.00pm. Got positioned at turn 1 for "recovery" (of crashed bikes and riders). Did anyone watch the National Supers race and see the 3 bike pile up into turn 1? I was there. 3 riders down, 2 out cold and 1 very pissed off. Good thing it was on the last lap, so the race had ended anyway. Took a while to clean that one up. Biggest highlight of the working weekend.
Biggest highlight of the non-working moments was the big FAIL to Vic police who capsicum sprayed half the pub when a fight broke out. That shit is nasty :P
Anyway, might go to bed again and catch up on more sleep :P
BTW the rear tyre on the Brutale got trashed :P
Edited by RubyRS4
hahaha thats funny as about the gtr stuff.......
thank god i own a non turbo tho :P so much easier but i must admit there was a dude in the N/A... section who said his car was non turbo but he had the Red/White GT Badges and on the rear bar he had a GTT badge..... i have to admit it was quite confusing until he said that the car had a non turbo engine put in it before he brought it. nfi why tho.
Went down to Michaels new shop Carline today. I recommend him, he did my exhaust at Aussies and really knows his shit. Plus he had a few 2jz's laying around, asked if I wanted to throw one in... Has really got me thinking..
ive only rally found the Do Luck ones and the ones that Viva Garage have got...........just spewin that i wont be able to fit GTR fenders on unless i change the bonnet and front bar :P
why does life have to be soo cruel in that way? :P
yeah gtr guards are basically for gtr front end conversion, unless you spend a mint getting them moulded onto standard fronts.
i want something a little wider with a vent, i love the look of the vent.
im not worried about spending the extra money on fitment cause the car will be going in for a full respray next year and ill get them put on when that is getting done....
krishey - u gonna come to loxton for dinner are you??? :P
and nah muirsky not getting new rims - i got them last year lol im really happy with the 19's anyway they look really good especially with this years graphics design :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
