went to main north nissan today and got the price for every stud, nut, and gasket between the engine and dump pipe. looking at just under $450 for the whole lot.
:EDIT: steve, check this shit out.
Edited by scandyflick
i mean cmon, look at the poor 33 they use in those chip advertisements
123977480_tp.jpg mmm, futuristic.
and the instructions:
"just take it to a TV repairer and have them solder it in"
as opposed to a, mechanic?
R34 chrissy today,, 4 brand new shiny RDA slotted rotors just rocked up...WOOT WOOT
just in time, the front factory ones are cracked to hell..lol
Yeah I gotta get mine replaced so I'll be lashing out for a set of RDA front slotted rotors too. Theyre not as expensive as I thought they'd be either.
-D
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
