600ml coke bottle, garden hose, gaffa tape
problem solvered
1 lap around lalla and it'll be full of oil.
you need a proper air/oil separator.
sinful has a good dual can setup.
I would use a partial plumb back can mounted above the cam covers (near the firewall) and a washer bottle replacement can (at least 2 litre capacity) with a plate baffle inside to bend the oil upon entry and a hidden breather under the can. SydneyKid uses stainless steel wool cans to bend oil but they're messy IMO.
here's a setup I was going to use before selling the R:
Primary top mount can with plumb back.
Main can (washer bottle replacement) large capacity with baffle, hidden breather & drain.
Showing hidden breather and dual washer pump fitment.
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
