i would say go with the RB25 Mitch
that way the can will be legal and wont have much hassles
but your call really
if the motor just needs a small scale rebuilt then do that
whatever you do mate goodluck with it and hopefully see you out and about soon
Im not sure what the law is but if you change back to a 25 you may need to go through regency so that they can approve the new engine number to make it legal. You may want to ring them and find out.
At work today thinking about next yr. Wondering if i should save up spend 10k on a engine or spend a month holidaying in Japan.
hmm hard choices.
Don't forget a 1/3 of that has to come my way :D
Pete it was finnaly good to meet you and have bit of a gas bag about the old Valiants!
yeah it was good James, cheers for the chat
I would also like a washer bottle that fits in despite my ic piping. I assume if Damo got one made up it would fit my car too? I can supply my oem washer bottle motor if he wants to integrate it (which would be preferable).
yeah, he'd do that with the OEM gear (basically it would be a solid replacement to the factory plastic ones)
oh, and cos i can
man i still lose my shit every time i watch this :(
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
Getting given 10 massive bags/boxes full of baby goods, and having to sort them out while massivly hungover= FAIL
finding 6 xxx DVDs in the bottom of one of the boxes, without wendy noticing = WIN!
i cant believe how many cops were out last night as it was!!!!! sooo many more than friday night
i know, i came from down pt noarlunga, there was an drug test van as ya head down into porties (just afta ya come round from murray rd), plus 2 separate RBTs on Anzac Hwy
surprisingly no cops at the bay or anywhere near hindley / rundle. most of their hindley fun has been taken out by closing that section off on a sat nite
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
