I spent this arvo getting the ute cleaned up ready to sell, chucked the old skylines seats in cos the Hilux seats looked like ass. Just need to do a bit of cutting and welding to the rear brackets to make them bolt up right :banana:
what kind of help?
btw, i cant find any info on this, anyone here an automatic genius?
basically my "power" button light for the automatic transmission flickers 16 times when i start the car up. doesn't happen all the time but it kept doing it last night, otherwise it shifts and drives fine??
Edited by tx3_90
what kind of help?
http://www.skylinesaustralia.com/forums/Rb...iew=getlastpost
anyone just see how a skyline driver got pulled off and ended up doing a runner and driving away and knocking over the police over? p plater in a black r33 series 2.
on Channel 7 news or something
Link?
Heaps of RBT's out tonight for the Adelaide Cup Day blitz.
Guest CleanAndSimple
yeah black gtst-t, r34 stockies on the front and standard rims on the back with a big kit, that the one? was on the news.
thats the one!, dont have a link becuase i saw it on the news.
look at what i found whist on ebay . :):banana:
http://cgi.ebay.com.au/Nissan-Skyline-R33-...A1%7C240%3A1318
Edited by CleanAndSimple
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
