theyre stupid is what they are.
and i cant even put into words how properly ridiculous this thing would be;
Years ago a Peripheral ported 26B, 4 x rotor job won Le Mans. If I remember correctly rotas were banned soon after
Rotarys are effectivley a 2 stroke engine (even thought they don't actually have a stroke) that is why they use more fuel but that is also why they produce so much power with such small displacement.
How about these apples;
Edited by D_Stirls
oh, ive bought a set of pads for the s14 as i can hear the current ones squealing, nothing special, just something to keep my brakes going til i get my qfm's and rda's, but uh... ive never changed pads on 4 pot brakes before, so would anyone be willing be help out?
they are the easiest setup to change i have encountered. the rears require a bit of fiddling to "screw" the piston back in, but they are still 10 times easier than my ford rears that also screw in and you need a special tool to do it (which i didn't have).
3 sided rotor is kinda like having a 3 cylinder 2 stroke with rotor apex seal opening/closing ports as seal passes/exposes the port
Yeah sucked big time. I still think the best days were when we had BMW's, Volvos, Ford Sierras, GTR's in the ATCC
Holden v Ford is a little boring imo
Word to mutha..... its a boganfest atm.... the group A's were much more interesting to watch.... too many rules in motorsport these days. I just wish it didn't come down to R&D budgets.... I reckon some of the early grand prix's in the 30's would be more interesting to watch than todays F1..
-D
-D
F1 which I've been following for nearly 25 years now has been pretty good still up until the last 4 or 5 seasons. Cutting capacity back to 2.4L V8 from 3L V10 and then the engine development freeze and then controlled ECU and now they've f**ked 'em up with new aerodynamics. Should be an interesting first few GP's this year....
Yep there is 3 power "strokes" per 1 revolution of the rotor but there is 3 revolutions of the eccentric shaft per 1 turn turn of the rotor. Since the output shaft is the eccentric shaft, there is 1 power "stroke" per revolution of the output shaft which is the same as a 2 stroke engine.
Edited by D_Stirls
C17
Snap, seen that before the Defence Air Show in 07 :D
Im officially "touring spec" at the moment
Sub box is being modified / re-designed this weekend, cos i got a bargain
Custom Sliding Drawer System for GQ Patrol (not properly in yet, still gotta bolt it all down and put a couple of dress panels in
Buttload of snatch straps - 2x 4t, 2x 2t, 2x1.2t straps, a snatch block and tree trunk protector, plus a heap of D shackles. Got a couple of different height tow hitches too, and a polyaire exhaust jack
ARB Touring roof rack (put in spot with a crane cos it was easier than trying to lift it lol)..........so now i got somewhere to put extra bits and pieces w00t
Edited by Matty 31
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
