im fking angry!
some wanker in a maroon 32 got full dori spec off brighton road into a side street (handbrake and all) the fk stain was doing about 80
i had to dive back on to the pavement, got a few cuts n grazes.
if you are on here, i saw your face, i know your car.....
Ohh wtf thats is just careless
glad that you got away with only cuts and grazes mate
More Kat Von D
much love for kat, you know she'd be an out there chick, and that shits just awesome, beats the hell out of a boring chick who refuses to try anything fun.
Most definitely.
"No boring bits!" :D
+1 shes hot... but too many tats for my liking too.
Had a chuckle not too long ago ...
Went on a night out with some mates, and was told I may not get in to some places due to my tattoos. I carried on about "you discriminating against the colour of my skin?" :) Ah, I guess it was one of those 'had to be there' moments :D
My point being, I blind man wouldn't find her tatts offensive. Its just skin and skin colour dude. :D
true ruby, very true
Id hit it.
lol
hey carl thats f**ked up dude,
yeah i know... im about to go for a bit of a cruise around the neighborhood, and see if i can find him for a chat.
injuries arent bad at all, just a bit shook up
its almost like she fell asleep while working a printing press for womans day and ended up getting sucked into the machine and printed with the gossip section, the agony aunt column and some pictures of angelina jolie...
-D
i might duck out back and cut up some aggh green ranger errrm and choof it down via mr.billeh
ahh hem
stag is with shaun today, on the dyno, told him couldnt afford anything more than a small tune atm tho.
really need to grow my own :) , .......
you never know Tangles, Shaun might look after you and do you a tune for cheap, seeing as you had heaps done there before!
ahh he does, he does :)
they are top lads down there
I cant see the bill being that much, $70 for shaft off/on, then basic dyno charge $80~
as I say to them, look after me and i go no where else, and am nothing but a patient understanding & (hopefully) good customer
query for the hardcore wastelanders
is there a market in SA for custom ecu eprom tunes?
something Im thinking of learning and doing...... learn on mine and then offer basic maps/install for others?
I would arrange dyno time, write a base map, check it out and write a remap... use 2-3 chips per customer, should only be a $300 all up customer cost?
a good emprom usb writer and a bunch of chips and adapters would be a grand start out costs
problem is the chips & adapters..... cost is around 15$ ea non-rewritable chips but adapters are 100 plus the soldering in .....
but yeah, sometime when Ive got 600hundrey to muck around with (tax?I paid extra the past 2yrs) I'll buy a eprom ecu burner and some of my chips, and muck around with it
"Chat" with him about a bit of road manners :)
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
