From Wheels August 1982
Its CAMIRA: "high flyer, high tech, high time"
rofl, thats everything a camira is NOT. decent work getting it airborn tho :wave:
http://cgi.ebay.com.au/WHEELS-AUGUST-1982-...A1%7C240%3A1318
Wow ... just had a massive project down at Aldinga land in my in-tray. Time to get back to work. Stop talking about my erection and do something about another erection :wave: This is going to keep me busy until the end of the day :P
so, my dad occasionally has fits of awesome.
im at work at the moment, jsut got a call from him, hes taken a half day and is heading out to main north nissan to pick up the feed line i need ($131 including new gaskets for the banjos), and is gonna fit it up as soon as he gets home, i *might* be making the dyno day in my car after all. heh.
but ehm, i removed a few things to find where the leak was, like the outlet snout on the turbo, anyone know what the bolts holding it in should be torqued up to? and what the banjo fittings should be done up to?
Okay, so I'm going to catch the O-Bahn bus today for the first time in like 8 years.
And I'm meant to catch another bus and get off at a place called 'Banksia Park'.
Ah, I hate when some of my mates are Northerners lol. I'm going to get so lost.
Depends which bus you get on to start with.... I know that don't help you much but if you can get on the right bus (I'm assuming in the city) you want have to switch/wait at Modbury
Catching a 542 bus? Apparently that goes from the city right up into Banksia Park.
I'm google mapping that shit up now.
rb20det, gtr injectors, stock ecu remmaped.
put a baffle plate in exhaust..
would that make it un driveable?
i was taking my mates car to regency and all off a sudden, running like a dog, black smoke pouring out..
WTF? prob only hit 2500rpm..
Unless the baffle plate clogged up the exhaust so much, it's causing back pressure and other crazy shit to happen, so the ECU makes it run extra-rich to compensate?
    • I think in the modern era we live in, if I were converting a hydro lifter head to solid, particularly when chasing revs, I'd be seeing what I could do to use shimless buckets. Those of us with Neos usually have this persistent niggling fear of a shim getting spat out and ruining everything. Shim-over is...yucky that way. At least the Tomei kit appears to be conventional, but it would still be nice if they'd decided to go shimless.
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
