I used a baffle plated cat to get through regency... never drove it hard the whole way there and back.
if you have a baffle plate and drive it hard then
the exhaust before the baffle plate will get hotter then the piping after the plate
that way they can tell....and defect you again for having a "non working/colapsed cat"
be careful with those mate
bahaha, profit.
We got a new vending machine at work, thought to myself, hmm, i fancy a kit kat.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :banana:
bahaha, profit.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :D
Get me a few while you're there :banana:
bahaha, profit.
The coke machine at work was giving everyone 2 cans at a time for about a week..... the bastards fixed it on Tuesday!!!
i know that with the newer coke bottle machines, the one with the conveyor belt, if u hold the flap closed and it doesnt push the coke out, it will drop another coke onto the belt then push both out. i saw a guy do it once :banana:
http://www.spike.com/video/how-to-trick-coke/2862499
Hey Chad if you want i can bring that 32 catch can to Villi's if your going. Give you a starting point at least.
Yeah, that would be awesome, we'll see i there is any room to fit it :banana:
lol Chad, oil is meant to go into your sump not your IC :D
Seriously though, with all that oil in there, were you monitoring your knock count on the PFC while going around Malalla?
Yeah i did, after every session i would have a look at the max's and there was nothing to bad.
Just went and got some degreaser, so gonna go give it a clean up and do an oil change ready for tommorow ;)
fark me, friday 13 th must be my lucky day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just won x2 4 day reserved grand stand seating + pit entry tickets + a harley ride in the drivers parade
on nova, all i had to do was sms the name of the driver
who won the first ever clipsal 500, of course, twas craig lowndes.
bout time i won something.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
