I used a baffle plated cat to get through regency... never drove it hard the whole way there and back.
if you have a baffle plate and drive it hard then
the exhaust before the baffle plate will get hotter then the piping after the plate
that way they can tell....and defect you again for having a "non working/colapsed cat"
be careful with those mate
bahaha, profit.
We got a new vending machine at work, thought to myself, hmm, i fancy a kit kat.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :banana:
bahaha, profit.
Put $1 in, registers on the screen, drops into the coin return, ok. Put $1 in again, $2 comes up on the screen, coin drops back into coin return, brilliant! Select kit kat, viola, paid $0 for my kit kat :D
Get me a few while you're there :banana:
bahaha, profit.
The coke machine at work was giving everyone 2 cans at a time for about a week..... the bastards fixed it on Tuesday!!!
i know that with the newer coke bottle machines, the one with the conveyor belt, if u hold the flap closed and it doesnt push the coke out, it will drop another coke onto the belt then push both out. i saw a guy do it once :banana:
http://www.spike.com/video/how-to-trick-coke/2862499
Hey Chad if you want i can bring that 32 catch can to Villi's if your going. Give you a starting point at least.
Yeah, that would be awesome, we'll see i there is any room to fit it :banana:
lol Chad, oil is meant to go into your sump not your IC :D
Seriously though, with all that oil in there, were you monitoring your knock count on the PFC while going around Malalla?
Yeah i did, after every session i would have a look at the max's and there was nothing to bad.
Just went and got some degreaser, so gonna go give it a clean up and do an oil change ready for tommorow ;)
fark me, friday 13 th must be my lucky day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just won x2 4 day reserved grand stand seating + pit entry tickets + a harley ride in the drivers parade
on nova, all i had to do was sms the name of the driver
who won the first ever clipsal 500, of course, twas craig lowndes.
bout time i won something.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
