we should do an event at marksman indoor firing range! pretty cheap, group of 5 people comes under 100 bucks each.
http://www.marksmans.com.au/indoor_pistol.html
i got told it was $80 for 40 rounds and you spend them in about 15mins :banana:
Lol ever seen a sleeping dog have a dream and it's legs start moving?
Here:
that has been sped up, still funny
Okay, so I'm going to catch the O-Bahn bus today for the first time in like 8 years.
And I'm meant to catch another bus and get off at a place called 'Banksia Park'.
Ah, I hate when some of my mates are Northerners lol. I'm going to get so lost.
oh noes dirty southerners in my hood
fark me, friday 13 th must be my lucky day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just won x2 4 day reserved grand stand seating + pit entry tickets + a harley ride in the drivers parade
on nova, all i had to do was sms the name of the driver
who won the first ever clipsal 500, of course, twas craig lowndes.
bout time i won something.
they obviously didn't tell you who you would be sitting next too :D
lol, I saw this coming the day Rann introduced these new laws.......funny how he couldn't see past his nose like the rest of us.
Instead of his laws splitting up these groups, they've brought together sworn enemies.
http://www.news.com.au/adelaidenow/story/0...?referrer=email
Its the same with a lot of shit that rann has done
They call him media mike for a good reason... he does a lot of insubstantial nonsense which makes him look like he's hardcore but has absolutely no effect in reality...
Interesting to see the amount of hydro shops getting firebombed....
Theres a book I read a couple years ago called "Getting Justice Wrong : Myths, Media, and Crime" by the emminent NSW lawman Nicholas Cowdery QC (Who just happens to be the Director of Public Prosecutions in NSW)...
He makes many good points about how the legal system more often than not does a great job but has no problem pointing out its flaws and how we can improve it. He goes on to write about how the "war on drugs" is a total waste of time and he is SCATHING of political involvement in the law, and does a very good job of deconstructing politicians and their baseless aims. He has an entire chapter devoted to how the politicians pick a cause and start acting like gorillas to make the public think they're tough/committed/intelligent/principled/moral/etc...It's no wonder that the NSW politicians have been trying to get him ousted for the last few years because he keeps throwing pie in their faces, but thankfully they haven't managed it.
If any of you even have the smallest passing interest in law and order, I highly recommend you hit your local library. Theres a copy in most and it only takes a few hours to read from front to end....
-D
the coppers have been taking low blows, knowing they cant do shit.... defecting brand new harleys on the show room floor lol, id hate to be the officer sent in there and tell the owner of the business im bout to defect his livelyhood
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
