we should do an event at marksman indoor firing range! pretty cheap, group of 5 people comes under 100 bucks each.
http://www.marksmans.com.au/indoor_pistol.html
i got told it was $80 for 40 rounds and you spend them in about 15mins :banana:
Lol ever seen a sleeping dog have a dream and it's legs start moving?
Here:
that has been sped up, still funny
Okay, so I'm going to catch the O-Bahn bus today for the first time in like 8 years.
And I'm meant to catch another bus and get off at a place called 'Banksia Park'.
Ah, I hate when some of my mates are Northerners lol. I'm going to get so lost.
oh noes dirty southerners in my hood
fark me, friday 13 th must be my lucky day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just won x2 4 day reserved grand stand seating + pit entry tickets + a harley ride in the drivers parade
on nova, all i had to do was sms the name of the driver
who won the first ever clipsal 500, of course, twas craig lowndes.
bout time i won something.
they obviously didn't tell you who you would be sitting next too :D
lol, I saw this coming the day Rann introduced these new laws.......funny how he couldn't see past his nose like the rest of us.
Instead of his laws splitting up these groups, they've brought together sworn enemies.
http://www.news.com.au/adelaidenow/story/0...?referrer=email
Its the same with a lot of shit that rann has done
They call him media mike for a good reason... he does a lot of insubstantial nonsense which makes him look like he's hardcore but has absolutely no effect in reality...
Interesting to see the amount of hydro shops getting firebombed....
Theres a book I read a couple years ago called "Getting Justice Wrong : Myths, Media, and Crime" by the emminent NSW lawman Nicholas Cowdery QC (Who just happens to be the Director of Public Prosecutions in NSW)...
He makes many good points about how the legal system more often than not does a great job but has no problem pointing out its flaws and how we can improve it. He goes on to write about how the "war on drugs" is a total waste of time and he is SCATHING of political involvement in the law, and does a very good job of deconstructing politicians and their baseless aims. He has an entire chapter devoted to how the politicians pick a cause and start acting like gorillas to make the public think they're tough/committed/intelligent/principled/moral/etc...It's no wonder that the NSW politicians have been trying to get him ousted for the last few years because he keeps throwing pie in their faces, but thankfully they haven't managed it.
If any of you even have the smallest passing interest in law and order, I highly recommend you hit your local library. Theres a copy in most and it only takes a few hours to read from front to end....
-D
the coppers have been taking low blows, knowing they cant do shit.... defecting brand new harleys on the show room floor lol, id hate to be the officer sent in there and tell the owner of the business im bout to defect his livelyhood
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
