Model: RB26DETT
Year: not sure
Milage: 90,xxx
Price: $3,000
Contact: Mitch , 0419-848-600
Comments:
Engine is out of an R32 GTR
comes with ecu and loom
engine still runs but could do with a rebuild as there is a small knocking noise
selling as the engine wasn't registered with my car thus not allowing insurance for me cause of my age etc
doesnt include flywheel but may be willing to part with my 4.5kg toda flywheel that is on it
engine is still in the car but is coming out this week.
Images:
http://i44.tinypic.com/2wdsdhw.jpg
http://i41.tinypic.com/fv8eu8.jpg
im confused mitch? wernt you saying that ur motor was dead and needed a basic rebuild?
i just went out and bought all the necessary cables to hook my lappy up to my plasma, and i have no idea why :blink:
i have nothing on my lapppy worth watching :blink: besides the 35 gtr doco that i have watched like 4 times...
what can i use my 5GB downlaod limit on...................??
no ,i never said it was dead , turns out the battery in the car didnt have enough power to turn the motor over .
started it up yesterday , was a loud noise , disconnected power steering pump and there was a small knocking noise in cylinder 6
car idles fine and revs up fine , just could do with some minor work .
craig, another option, is mininova, isohunt, or the pirate bay to find torrents.... and cant go past utorrent as your download client.
:blink:
ill suss out a bunch o details about my mates 32's, and pass em on to those that are keen-o
as stated friday, i won 2x 4 day passes,main strait grand stand, and cant attend thurs fri, so, if you can promise ill have both passes
back friday night, ill be happy to lend them out, providing i know who you are lol
im just lookin forword to the harley ride round the track lol
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
