Better yet, just give Dave the $900 and he can be the hooker and I'll still get a blowj....
Wait... :P
:D
I'm a bit busy trying to sort shite with the new vehicle today, but if I get a moment I'll get on yahoo for ya :P
cheers man no rush
On another note I fking love my new car :thumbsup::banana:
I never knew RB20s could be so torquey :O even being hampered by 3.9s in the diff and 215/60/16s on the back it still accelerates smoothly and quickly from no revs.
Can't wait till I coin up and chuck a 2way in it with 4.3s and some 205/55s :banana: :banana:
Edited by AndrewJZX100
LOL yeah I dunno they just look weird. How massive is that wing though :thumbsup:
Also, no luck on the guards Steve. There was only 2 ads which featured that blue 4 door with them and they were for 'side step' and 'RIYAUINGU' (rear wing) :banana:
Might check again tomorrow or something, I think the ads usually have a day or so turn around from when their old one ends to when they put a new one up.
stupid question yes but how do you fill up a bucket at the local happy wash type of car wash?
i know this guy that knows a guy that put his car wash stuff ready in the bucket and hit it with the highpressure hose. resulting in about 100L of foam covering him and about 2 drops of water in the bucket.
................yes that guy was me. doh :thumbsup:
If I ever sell up/someone writes it off... hello V35 350GT... would make such a good daily. Doesnt have the look of the typical Skyline so doesnt attract scumbags - blends in with the Camrys and the Commodores lol
lool, stoopid ass! :banana: you didnt think to use one of the "non high-pressure" options, like spotless free rinse?
lool, stoopid ass! :thumbsup: you didnt think to use one of the "non high-pressure" options, like spotless free rinse?
Spitting in the bucket would have filled it quicker too :banana:
mate most happy washes have a tap spout near the little house deal where you get coins???, (for washing out sham's or filling buckets),, or put the soap in after the bucket is full...and stir with hands to make foam..???? another way spray the sprayer into a rag to keep the water in the bucket while filling on high pressure
keeps you from looking like a frothy maniac escaped from glenside..hahaha
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
