my house mate told me yseterday that he brakes are making noise....
just had a quick look, i think i can see the problem...
can u say metal on metal?
those are the deepest grooves i have seen on a disc, they are about 3 - 4 mm deep
yeah looks good Matty but don't know how comfy the Patrol boys would be having a 200 around..........lol, it won't matter whether I can keep up with them or run rings around them, the fact that it's a 200 will get me flamage.
EDIT: Not to mention that I'm still running the factory Dunlop Grandtreks (crapiest tyre ever designed for a 4WD). Need to put some M/T ATZ's on there but I'd be looking at almost 1/2 grand a corner :D
i dont think they'd mind. someone always brings a mate along with another make of 4wd, there tends to be floaters with pajeros, cruisers and the likes. even on the Patrol Club of SA outings they've had Jackaroos and Subaru 1800 wagons :(
Im keen to see how the new Kelly Safari Trex go
i want some custom slots like that in my rotors too. it has a great feature of screaming like a banshee all the time... i need that too
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :D
-D
just get some RDA slotteds from Rianto (rs73)... he'll hook ya up for a good price :(
-D
unsubstanicted clap trap i dont appreciate that post there is nothing wrong with RDA rotors its the pads and how you bed them in
dont take this the wrong way
haha cheers craig :D
I never said anything about RDA rotors except to buy them. I've ordered some myself... WTF kinda high horse are u on today? Don't appreciate what post?
-D
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
