Reuben, its not SMASA - SMASA is Street Machine Association of South Australia which was the previous show... tomorrow is Old School & New Age Auto Show :D
:P
Err ... I knew that :P
nomination for thread of the decade, almost cried with laughter a few times http://www.skylinesaustralia.com/forums/Co...ead-t56368.html
2 hours til works ends for the week, cant wait.
speaking of funny, while I was on the job and in the middle of filming, my phone rang (normally turn it off if I remember).
Looked at it on the bluetooth (which is setup for auto answer after a few rings) and there was Mr (smartass) Madaz's name?
I kept filming as the thing auto-answered just to have Rick Astley pumping thru my car speakers and onto my video....could've killed the bugger (and I probably still will)!!
Ah, that would have been priceless for the client :P
lol just got pulled over for absolutely nothing (apart from being guilty of driving an import) while on a drive with my mum :P
They followed me out of littlehampton for a few kays, I knew it was gonna happen. After they'd finished they turned around, meaning they only followed me out of the servo and 3/4kays down the road to pull me over (in a stock looking Silvia) :/
Had they been called for an actual emergency in Mt Barker or somewhere they'dve lost minutes on response time for the sake of hassling another import driver.
Even my mum said it was utterly pointless :laugh:
Andrew, I got pulled over just then before just after lunch... just infront of my driveway! lol was in my dad's 4WD though - this silver VE Commodore speeding down the road to flick it's lights on just as I indicated to turn in my driveway... just to do a "random" license check.
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
