daaaaam she hot!
im bout to watch zack and miri make a porno, many rofllol's to be had me thinks.
also just wanted to express my disgust about the crash this morning, i know some died, but fuuk me, 150 k on
magil rd? dick head.
+1 for more negative press on imports, congrats.
yeah hi nice to meet you too.
Not sure but I think I know where Craig's going with this.
We discussed this subject as recent as last night at Villies.
I think ns insist on 50 posts before flogging your wares on their site....not a bad idea.
Oh well, I don't make the rules, just try to enforce them.
you read my mind like a book there Pete.
think its 100 posts for ns,
i'd be all for it too... but that may require a sub forum with a different rule set
(just guessing here, the forum that i am admin for can only do this for a sub-forums/groups of threads, not just an individual thread).
im sure nightcrawler would be able to suss it out
OK, I've moved the discussion here otherwise I'll have to ban myself.
100 posts is a good idea but even 50 would be better than what we've got.
well I might take the kids to the drive-in tonight....weather is looking good and there's a couple of good movies on.
If anyone heads down there, look out for a new white Landcruiser near the projector cubicle.
I just checked the prices for the drive-in.....when did they change?
I reckon it used to be approx $15 per car for 1 movie then another $10 for the 2nd and so on for a 3rd.
Now it's $20 per movie!
Oh well, can see another drive-in closing down pretty soon.......buggered if I'm going to spend $40 for a couple of average movies....might head to the video shop or checkout FoxBox.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
