When i first saw the post about alot of sklines and wrx's will be getting random pull overs i thought yeah right cops wont bother to much,
but today on my way home after work i got pulled over, the cop said to was talking on the phone which i wasnt she didnt know what to say so i show her my recent calls and my dailed calls showing nothing in the last 10 minutes. thanks god i didnt get done since i really wasnt on the phone ive been done before for that so ive learnt my lesson now i oull over!
then she says i can defect your car for the steering wheel which its a momo and is not defectable didnt know f**k all.. just gets me going!
anyway throught i would share this you people!!!
I just scraped the crap out of my front bar, and I just had it painted like a month ago
DAMMIT!!! Goddamn cheap fruit place just cost me!! Save on fruit on veg but scrape the crap out of your car!!! :P
Congrats! :P
What doing? ... any SAU freebies? ;)
thanks! 3 weeks unemployed was sending me silly! still got 2 wees before i start too!
unfortunately no freebies lol, will be working for an agent of workcover! so hopefully won't have to deal with anyone from here :D
ERRRRRRRMMMM
i just got an internet bill for $1,053.92!!!!! FOR THE MONTH!!
i get my bills via Bpay, so i cant read the summery.....
considering my bill is usually 50 bucks, i think ill be getting wendy to give them a call and find out wtf is going on!
dave, that download site doesnt charge to join does it?
nah not a case manager it's a different section, will be just entering all the information required for a claim n then processing doctors accounts for payment, but they said i can get into case management if i want too
ERRRRRRRMMMM
jeez man, shoulda just got the dvd's instead of downloading your porn, woulda been cheaper.
nope, no charges associated with that site. file sharing. keyword.
how much did you download though? your isp mightve just decided to rape you if went over your cap.
5 gig downlaod limit, and i downloaded 6 gig, surely not worth an extra grand!
If you're with tel$tra, then yes, it'll be around a grand... they charge stupendous data rates above the set data limit.
They charged me and my housemate $1200 twice when they implemented a 3gig limit on their ADSL back in 2002 (where previously it was 'unlimited')... but since they were utter conniving scumbags about how they did it (without informing their users) we had the ACCC on their backs and they refunded all the excess costs..
Tel$tra are scumbags... theres no way around it, theyre absolutely utter immoral bastards, so I'm real glad they've (hopefully) lost the national broadband rollout...
Telecom was incompetent back in the day. As soon as they privatised, they became incompentent and money hungry. Never a good combination.
-D
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
