Here is the details, any one care to translate to english for me?
ACCOUNT DETAILS
Calling Line Identity Status as at bill issue date:
Your number is displayed to others unless 1831 prefix dialled
Payments
Details Date Amount
Payment received - Thank you 21 Mar 49.98CR
$49.98CR
USAGE CHARGES
Service Charges
Details From To Amount
Monthly 'yes' Everyday 5GB Access Advance27 Mar 09 26 Apr 09 45.44
Short Messaging Charges
OPTUS SMS/Group/Email SMS 3.63
Billed Messages 16 units @ 0.227
'yes' Everyday 1,820.27
$1,869.34
Plan Options/Bonuses
Details Amount
yes Everyday Incl. Value Credit 911.18CR
$911.18CR
TOTAL USAGE CHARGES $958.16
'yes' Everyday - Tiered Charges
Tier Price ($/MB) Volume Amount
0 - 7340.0 MB .0099 7340.032 72.666
over 7340.032 MB .1331 13129.970 1,747.599
Total Volume: 20470.002 MB $1,820.27
4.50 - 000237 - 021139
à
how the f**k did i downlaod 20 gig? i think its wrong....
did you leave your peer to peer software running? optus and telstra both charge uploads as part of their 'acceptible usage policy' (usually= download limit but since they charge for uploads too, you might very well be screwed here)
-D
na, i only leave limewire on while im on the comp, never leave it going, specially if im not downlaoding....
just see what they say,, we will play fair for as long as they do...
commence being on hold
nnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnow.
if you were using demonoid youd be using something like bitlord to download the torrents, if you were downloading high demand movies, your upload rate wouldve been just as high if not higher than you download speed.
dude i feel for ya and all.... but how did you go 15gb OVER your limit and not know it??
Hope you can sort that out, who has a grand to throw away!!
must be all that german porno he downloaded
"Essen mein sheisse!"
-D
yeah, I'd imagine the streets of Adelaide will be considerably quiet over the next few weeks due to recent events..... I'm sure it'll pass though.
Late reply:
It's easy to say it'll die down, which it probably will. But as soon as it does decide to die off you can guarantee that someone else will f**k it up for everyone or it'll be x-mas holidays. Sad really, I've been thinking really hard about selling up because I cannot be bothered with all the bullshit that will be going on from now on.. I don't even see the point in getting the car off defect for the time being.
Late reply:
I don't think there is an issue. I believe that the police at least have not tarred us all with the same brush and know that the street racers are in a minority.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
