just thought id give an update bout my over sized internetz yo' bill....
yup, apparrently i downloaded nearly 20 gig,
the way i was keeping track of it, is ''outdated'' as i have the ''old modem'' (words of indian/asian from optus)
so...therefore, on the 26/3/09 when i checked my usage (last day of billing cycle) it said 6 gb downloaded, it was in fact nearly 20.
they failed to tell me about this, my download speed didnt even slow down!
do i have a leg to stand on here? may to get the bill reduced? pete? anyone? question mark??
Bend over and use lots of vaseline! :D
Tracy use to work for the Optus complaints dept (for people like you) and there's not much you can do sorry. :D
Absolutely. If the AUP was not working then its grounds for a reduction - providing that there is no clause in the terms and conditions which waive liability if the meter isnt working properly...
I'd call the telecoms ombudsman - they handle broadband complaints. tell them that you checked on the last day of the billing cycle and that it reported 6gb and not 20. If optus has changed the way the meter works/have broken the traffic accounting system without notifying you or providing a viable alternative then they have no option but to refund the difference. You'll still have to pay the excess 1GB naturally but with enough kicking and complaining I think you have a good leg to stand on here, especially if they provided the modem (im assuming you're checking the download usage by your modems inbuilt meter rather than a website on optus?)
regarding slowdowns - either you get a capped limit and anything over is free but on dialup speeds, or you get full download speed and any excess is charged on a per megabyte rate - its one or the other and you'd be best off clarifying exactly what here, because its one or the other.
-D
its there fuukin fault really for giving me a device that misleads usage!
haha, they even said if i wasnt happy with the service, i could pay another grand and cut the contract early by 7 months....
fuuk you optus.
yeah ben, i check usage on the stats tab (from the modem)
they said since the new modem has been released, the old one (mine) doesnt count correctly.
Well then they're up shit creek for not a) supplying you with a modem and b) notifying you of the change.
You'll win. Easy.
-D
the ombudsman agrees, i have to call optus, and request a stop credit management.
i have to pay 49.98 (usual bill) and optus has 10 days to respond to the TIO in regards to the 1003.98
Good work! Its amazing how many times these arsehole internet providers try and shaft you. Always the big guys like Optus and Telstra (telecoms companies providing internet as a service)... I can guarantee you that Adam and Internode wouldn't pull that nonsense (Adam and Internode being primarily internet providers and not massive corporations trying to get more for their shareholders)...
I think Optus will argue that since your modem showed 6 gig out of the 5 gig limit that they're entitled to an additional $150 - this might be the only problem you'll have, but even still $200 is much better than $1100 - if you can get away with $50 only then that'd be ideal..
In the meantime, I'd advise everyone out there (in SA at least) to switch to either Adam or Internode - you'll get one hell of a better deal.
-D
cheers for the advive there Ben, much appreciated!
my mate is with internode, after his download limit, his speed is cut down, and DOESNT get charged for over use.
guess where ill be taking my custom soon.
i dont mind paying 200 bucks, fair nuff, but over $1000 for 1 month internet? c'mon, get real.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
