guarantee my daily has more HP than any of yours, and more torque...
.............................................................................. It's a bus.
Who'd like to help me fit the roof sheeting to my house extension?
Serious question! I've been on the extension all day fitting the purlins and double checking the tension ... and I've had a gut full already! :banana:
Reckon I've been up and down that f**king ladder over 100 times today! :(
and i am still laughing at that comment....
as chad left Dans statement was "DSTROY, my ass"
note the comma there krisy.
scandy was a lil emotional of the lack of burnout. im awaiting the day of a bogan attack as a result to your comments scandy. ive seen sh*t like that happen before at the good old glenelg car park :banana:
Edited by Inline 6
Someone sell me a stock RB20/25/26 BOV.
Please? :banana:
^^ what for?
well??
this could be taken as 2 ways as in how much are you hoping to pay and
why do you need one to clear regency to borrow or because you don't want dogs bollocks sitting in your engine bay saying please send me to regency
Bloody regency. Trust them to make Dogs bollocks defectable.
Bastards.
-D
shutup Ruby :D
Happy Easter SAU family.
got pulled over leaving the alma last night, car is unregistered and i had no idea :P Gave me a breatho, and told me to go straight home and pay it (which i did) Cops were awesome guys, asked me how much i paid for my rims, then said "nice" :banana:
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
