jesus... thats so incredibly f**ked up. hope the guys that did it find themselves in a very dark alley being confronted by entirely the wrong people and never heard from again.
I got re-aquainted with my couch, slept a lot, did a "Friends" marathon and bought a rug.
You've got to haggle haggle.
On a serious note, anyone looking for rugs should head straight for haggle co, we went to rugs-a-million formerly solomons rugs then went to haggle, MUCH better prices for much bigger and better quality rugs. Rugs a million had 1 sales person on and 2 customers in the store, haggle had about a bizillion people working and the shop was chock-a-block full of customers and I can see why. Bought a big white shaggy rug (for shagging).
The price was so good I didn't even haggle and what I walked out thinking "(!!!!!) You idiot the store is CALLED haggle and you didn't! What's the matter with you!!"
Where did you go up river Carl? We have family property at Sundlands/Hogswash/Waikerie and went up there for a night Thurs Friday. Fishing was a bit slow, but still managed to get a decent size Redfin, and a couple of nice 50cm Callop for dinner. The mixed half a dozen of red wine (incl. 04 Redman Cab Sav, 02 Leasingham Classic Clare Cab, 00 Pepper Tree Shiraz and others), bottles of Wild the sphincter of the universe and Johnny black, after downing a carton of James Squire Golden Ale and a carton of Palies in the afternoon made for 5 VERY sore heads on Saturday though :D
i was on a property called cordola that is about 15 k south of morgan. its awesome cos there is almost nothing there, have to take water, and dig a hole in the ground for when nature calls.
its pretty much my favourite time of year because i can jst unwind and spend days asleep under a tree, or asleep on a boat holding onto a fishing line (we didnt catch a thing lol)
joisus, got a bit of a shock today. went to nissan to price a high spec lip for the 200, they wanted close to $1300 for the f**kin thing. yikes.
on the bright side, compression test came up good, 140-145 across the board, leak down test didnt show anything note worthy (or anything at all rather), and i found a seat rail for my velo. awesomes. :D
now i just gotta source a lip and some rear pods though... ;)
OMG check this out!!!!
this is the title of the thread... just for a tease "what happens when you get bored of 600bhp cosworth granada ? you put a koeniggsegg ccx v8 in it"
whoa, decent build! still, in a ford cosworth?
Not the prettiest car around, but you have to appreciate the work put into it......
Not too bad, did all the family visiting stuff and pretty much sweet fa else. Painted my calipers on Monday.....
http://www.skylinesaustralia.com/forums/Pa...0&start=100
You?
House extension mostly ... naturally. Got half the roof on now. Threw on a few DVDs I've been meaning to watch again. Cleaned by pool. Did some bloody homework for TAFE too.
... plus did the usual 'drop in on family' :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
