jesus... thats so incredibly f**ked up. hope the guys that did it find themselves in a very dark alley being confronted by entirely the wrong people and never heard from again.
I got re-aquainted with my couch, slept a lot, did a "Friends" marathon and bought a rug.
You've got to haggle haggle.
On a serious note, anyone looking for rugs should head straight for haggle co, we went to rugs-a-million formerly solomons rugs then went to haggle, MUCH better prices for much bigger and better quality rugs. Rugs a million had 1 sales person on and 2 customers in the store, haggle had about a bizillion people working and the shop was chock-a-block full of customers and I can see why. Bought a big white shaggy rug (for shagging).
The price was so good I didn't even haggle and what I walked out thinking "(!!!!!) You idiot the store is CALLED haggle and you didn't! What's the matter with you!!"
Where did you go up river Carl? We have family property at Sundlands/Hogswash/Waikerie and went up there for a night Thurs Friday. Fishing was a bit slow, but still managed to get a decent size Redfin, and a couple of nice 50cm Callop for dinner. The mixed half a dozen of red wine (incl. 04 Redman Cab Sav, 02 Leasingham Classic Clare Cab, 00 Pepper Tree Shiraz and others), bottles of Wild the sphincter of the universe and Johnny black, after downing a carton of James Squire Golden Ale and a carton of Palies in the afternoon made for 5 VERY sore heads on Saturday though :D
i was on a property called cordola that is about 15 k south of morgan. its awesome cos there is almost nothing there, have to take water, and dig a hole in the ground for when nature calls.
its pretty much my favourite time of year because i can jst unwind and spend days asleep under a tree, or asleep on a boat holding onto a fishing line (we didnt catch a thing lol)
joisus, got a bit of a shock today. went to nissan to price a high spec lip for the 200, they wanted close to $1300 for the f**kin thing. yikes.
on the bright side, compression test came up good, 140-145 across the board, leak down test didnt show anything note worthy (or anything at all rather), and i found a seat rail for my velo. awesomes. :D
now i just gotta source a lip and some rear pods though... ;)
OMG check this out!!!!
this is the title of the thread... just for a tease "what happens when you get bored of 600bhp cosworth granada ? you put a koeniggsegg ccx v8 in it"
whoa, decent build! still, in a ford cosworth?
Not the prettiest car around, but you have to appreciate the work put into it......
Not too bad, did all the family visiting stuff and pretty much sweet fa else. Painted my calipers on Monday.....
http://www.skylinesaustralia.com/forums/Pa...0&start=100
You?
House extension mostly ... naturally. Got half the roof on now. Threw on a few DVDs I've been meaning to watch again. Cleaned by pool. Did some bloody homework for TAFE too.
... plus did the usual 'drop in on family' :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
