Same with ford fairlanes like my daily. They had an rear airbag setup to level the car once a trailer/caravan was placed on the tow bar, Since it was $1000's to fix it once it broke most people replaced it with coilovers once it died.
yeah, factory 'yota bags are pretty average, especially at this age, while its mad fun droppin the ass and liftin the nose on hindley street, theyre pretty useless really. dampening sucks. you can buy 're manufactured' bags from an american company called 'arnott industries', but they have a fairly short life span apparently. hell, you can even buy air struts with bilstein inserts through them. pumps you can find second hand, but even then theyre crazy expensive ($1000 private, up to $2000+ from a wrecker). just get coilovers.
dont be put off by the rather high spring rate you tend to find for coilovers for these things though, theyre heavy beats, so 15-18kg front springs tend to be the norm.
:edit:
pm sent dude, also check this out, stance in the us, theyve got 5 types of coilovers, from your base model stuff all the way to remote reservoir racing stuff, thats a link to the GR+ which is 1 step above entry, 18/10kg springs, which is normal for 'yota gear. enjoy.
then theres; HSD TT Series, HSD HR Series, ISC N1 (says its only available for 97 on though, might wanna check with ryan), and racing logic.
Edited by scandyflick
lol but can those stock airbags be modded easy to get the wheels bouncing off the ground?
nope, for a start the air lines and valves are WAY too small, along with an asthmatic compressor and tired pump, theyre pretty useless, takes forever to lift and drop. only way youd get it bouncing (or moving faster than youre average snail) is a very large airtank, one pump per axel, upgraded compressor, 1/2 inch or bigger lines, and suitable valves... and you know, new struts.
oh Dave some people have no taste :blink:
haha, yeah, its pretty ordinary...
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
