Same with ford fairlanes like my daily. They had an rear airbag setup to level the car once a trailer/caravan was placed on the tow bar, Since it was $1000's to fix it once it broke most people replaced it with coilovers once it died.
yeah, factory 'yota bags are pretty average, especially at this age, while its mad fun droppin the ass and liftin the nose on hindley street, theyre pretty useless really. dampening sucks. you can buy 're manufactured' bags from an american company called 'arnott industries', but they have a fairly short life span apparently. hell, you can even buy air struts with bilstein inserts through them. pumps you can find second hand, but even then theyre crazy expensive ($1000 private, up to $2000+ from a wrecker). just get coilovers.
dont be put off by the rather high spring rate you tend to find for coilovers for these things though, theyre heavy beats, so 15-18kg front springs tend to be the norm.
:edit:
pm sent dude, also check this out, stance in the us, theyve got 5 types of coilovers, from your base model stuff all the way to remote reservoir racing stuff, thats a link to the GR+ which is 1 step above entry, 18/10kg springs, which is normal for 'yota gear. enjoy.
then theres; HSD TT Series, HSD HR Series, ISC N1 (says its only available for 97 on though, might wanna check with ryan), and racing logic.
Edited by scandyflick
lol but can those stock airbags be modded easy to get the wheels bouncing off the ground?
nope, for a start the air lines and valves are WAY too small, along with an asthmatic compressor and tired pump, theyre pretty useless, takes forever to lift and drop. only way youd get it bouncing (or moving faster than youre average snail) is a very large airtank, one pump per axel, upgraded compressor, 1/2 inch or bigger lines, and suitable valves... and you know, new struts.
oh Dave some people have no taste :blink:
haha, yeah, its pretty ordinary...
    • I found a supplier for an arm in NZ. https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-rh-side?srsltid=AfmBOopMdfCFDc_8yVZZ9kq5nIngPHRTBzUU8v4SAptJaRO52Wjs0bC6 I looked closely at the photo of that one and the Z1 arm, and it's the same bloody arm. Scratches all match in the photo 😂 How hard is it to change that joint? Also they seem to be listing two options https://thrashgaragenz.com/products/nissan-skyline-v35-z33-350z-front-lower-straight-arm-balljoint-rh-side?_pos=1&_sid=229acde44&_ss=r And now I have no idea what size I'd need yay
    • Ill review it again, from memory when I first saw some of Trailer Park Boys I wasn't a huge fan. I ended up at Letter Kenny after watching Shoresy, which is a bit ass backward, ha ha
    • "lol dunno" either But like you, I can't see any reason they would need to be different LHD to RHD
    • I agree with you WRT the hard top. MX5's may be one of the better looking soft tops but I cannot think of ANY car, EVER that looks better with a soft top vs a hard top (or a designed roof). At all, ever. I also feel this way about the C5 Vette, the Z06 looks horrible compared to it's original form, it has an exaggerated version of the differences you're talking about.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
