de-fragging FTL
1 hr = 32 %
sigh.....
how can i make this thing faster?
toshiba, intel celeron 1.6 GHz, 896 MB RAM...
Dont use windows defrag. its shit.
use PageDefrag for Windows by sysinternals
its the bizzomb.
-D
as long as it rains AFTER 12pm on saturday
if it rains any earlier i will scream
do NOT want to have to iron my uniform AGAIN
are u one of the girl guides that helps with the flags at dawn service...
i hope it f**king pours
except when we're outdoor doing dawn service. but if it does, so be it.
bacon n eggs with the diggers is worth a few drops of h20
-D
They said rain last year too, and it was a pearler of a day in the end. I'm hoping it's clear too - I've got a detailer coming to do the GT-R Saturday :S
Oh and my new Y34 Cedric arrived today - by tomorrow night or Friday morning, it should be registered, slammed and rolling on 19s B)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
