i got approx 5litres poured on my lap this morning while driving to work. dato is not impressing me during these winter days :banana:
a slow drip has now become a steady pour :bunny: look forward to calls of har har :bunny:
any 1 got welding skills? apparently the roof has rusted through and my ton of silicon around the window can not stop the onslaught.
Edited by Inline 6
as mentioned previously i have a soft spot for that car. i try to kill it via thrashing but it dosnt die.
ive started looking at cars but all the cheapish cars seem kinda boring, id like to stay rwd n such. so far cars i seen that look alright mini and 280zx
Edited by Inline 6
yeah but 138hp wasnt enough, i somehow think the rolla wont match that. and i used to bang it off the rev limiter when i take off everytime with the auto stick jammed in 1st n 2nd before letting it go into D
i dont care what it looks like more concered how it drives. working heater and no leaks would be a nice touch :banana:
are poobird sss any good? 1.8L
also whats the link to your damn rolla?
Edited by Inline 6
primer :banana: dosnt look to bad might chuck him an offer on it. any 1 wanna get funky with spray cans if i get it? :bunny:
also with the vic rwc that dont mean bugga all diff if your bringing it here does it? Its still gota go through regency all the same?
Edited by Inline 6
you dont need another f**king car, lol, any more and youll need an LMVD.
marrone r32 - track project
white r32 -sold
gold/now black datto - sold
falcon
rolla - chucking CA in it
still leaves the falcoon.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
