selling roof rack isnt easy haha. mind you, just found out its universal gutter mounting. ebay sucks for trying to do anything atm, trying to upload a pic again and its not playing ball
lift kit rocks in monday w00t w00t
yeah ill be running a surge tank, hoping to keep the walbro 500hp fuel pump i got for the surge tank and then have the 1000hp external pump going to the fuel rail.......basically the pump ive found is equilvant to two bosch 440's.
# For high horsepower EFI applications making up to: 1600 HP - Naturally Aspirated
# 1100 HP - forced air induction
# Now with more flow and extended warranty
or
http://www.rocketindustries.com.au/search.php?brand=Fuelab
Yeah but more looking for something that i'll have no chance (well i guess nothing is impossible) of modifying in any way.
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
